Hi,
looking for a replacement automatic gearbox for a friends truck.
its a 1993 toyota prado KZJ78. will use anything available.
prefered in christchurch.
Thanks
WANTED : 1993 Prado KZJ78 Gearbox Auto
Re: WANTED : 1993 Prado KZJ78 Gearbox Auto
Still looking if antyhing has popped up? please
Thanks
Ben.
Thanks
Ben.
rick @ 4wd accessories might still have my old one, you might be able to make a good one from two bad???? depends whats wrong..
Who knew Prados could fly?
definitely don't want a manual one?
Thanks, ill ring Rick on monday.
He is keen to keep it auto for now. but if we cant get a replacement it might be the only option.
if it is the same as the auto box on a 1kz surf i have one sitting in the garage looking for a new home. According to toyodiy it has the same part number. You can have it for $150 with the torque converter. It was mint before i pulled it out. I just wanted a manual.
Sam
Sam
jammysammy wrote:if it is the same as the auto box on a 1kz surf i have one sitting in the garage looking for a new home. According to toyodiy it has the same part number. You can have it for $150 with the torque converter. It was mint before i pulled it out. I just wanted a manual.
Sam
Its not, you can swap bits, but the back end and shifting are different
Argg, great price too. would have been so keen. ill see if i can find out whats involved to use it.
im looking for one too
or at least the back bit from the adaptor back..
scarce as rockin horse shyt
