got a chassis sitting in my garage which i am trying to empty, has front and back diffs still in it, both are in good condition, if you are interested make an offer ( cheaper if you come take them out yourself)
i am in chch
d21 diffs
- mayhem1982
Re: d21 diffs
Navara or Terrano? Does make a difference. Ratios?
- mayhem1982
Re: d21 diffs
terrano, 3 door, td27 non turbo. how do i tell what ratios they are?
Re: d21 diffs
On the Id tag, bottom right side is the drive axle code. Most likely CA48.
Does the rear diff look like this? With the plate on the back.
