Nissam Mystral TD27 hard to cold start in the mornings
Hi , I am assuming the obvious here and that it is the glow plugs that need replacing , its a 1995 , TD27 , 200 000 on the clock..... I have a mechanical warranty on this vehicle and also wondering if the glow plugs will be covered?
Re: Nissam Mystral TD27 hard to cold start in the mornings
hi
could well be glowplugs. if you have a multimeter or a bulb and a bit of wire, you can test to see if you have power to the rail and see if the glows have died without having to take the glows out.
no idea about insurance. glows don't cost much so probably not worth it. also they may class it as wear rather than breakage.
Nissans are real bad for the glow timer not matching the light. Let it glow and wait for the click of the glow circuit turng off rather than the light and see how it starts. If it still starts bad check the glow plugs.
