Mitsi adjustable height
WHOOPS
Post by WHOOPS »
Can someone pleaseeeeeeeee tell me how to get rid of the speedcut or which wire I can put a switch on??? been looking everywhere but can't find anything :(
thanks guys
Cameron
Re: Mitsi adjustable height
Post by Cameron »
raise it up.
turn key right off. start up and move on.
at least, that works on mine, however it'll probably eventually 'sink' again due to internal leakage of the little solenoid valve thing that opens to lower it again.
WHOOPS
Post by WHOOPS »
serious? lol think ive tried that and doesn't really work for mine... need to find which wire to the ECU for the speed limit thing so I can stick a switch on it..
WHOOPS
Post by WHOOPS »
Anyoneeeeee? :)
CLUMZ1
Post by CLUMZ1 »
Where are the sensors? You could possibly raise it like you can lower/raise a P38 by moving the height sensors on the suspension.
Smurf
Post by Smurf »
There is info on the net, we have done this to a mates Pajero a few years back. The pajero is long gone now though.
I had a quick look and couldn't find the info, but we did find it on the net initially when we did the mod.
From memory the wire you need to put the switch in is located in the right side panel.
You could find which fuse it runs on and put a switch on that? Provided it doesn't run anything else?
WHOOPS
Post by WHOOPS »
yeh ive been so much time trying to dig around the net for info on wires and sensors and all that but just couldn't find anything... ill just have to keep looking i spose.. :)
Smurf
Post by Smurf »
Trace the wires back from the pump in one of the rear wheel arches (I think) to the ecu and test the wires from there?
WHOOPS
Post by WHOOPS »
yeh could be the plan... cheers mate
pjb
Post by pjb »
The control module is on the same bracket as the rear locker pump, on the LHS in front of the rear wheel well, behind the quarter panel. Bit of a bastard to get to. It'll be labelled MB629784.
One of the wires going in must be speed. Pop one wire at a time out of the harness connector until you get what you want.
94 Pajero SWB, 3.5 V6
WHOOPS
Post by WHOOPS »
Will give that ago thanks mate
JohnySWB
Post by JohnySWB »
So sorry I saw your question the other day and didn't have the time to answer then and then forgot to get back to you. I have done this my self and know the answer is good
The answer is.
1/ Open driver's door and in the bottom of door frame remove the screws that keep the bottom piece of grey plastic kick strip trim in place. Remove the trim.
2/ There you will find some thing like 8 to 10 wires going to the front and under the dash.
3/ Find the white wire with blue painted on rings around it. This wire is the one that tells the hight adjust to drop down. Simply cut the wire fold back the ends on each end and wrap insulation tape on them to keep tidy and safe from touching body.
4/ Your job is done bar putting cover back on.
The only oddity to this cure is I found one Paj where the wires were on the left side (passenger). But the same wire applies.
Taking the dash apart is a lot more work and a little more possible dangers
involved of something going wrong. My method is a whole lot easier to put back if required for some reason .
Cheers.
WHOOPS
Post by WHOOPS »
Dude your a legend hah thanks heaps will go cut wire now :)
WHOOPS
Post by WHOOPS »
Yeh couldn't find a white wire with blue painted on rings around it so will have to look at the passanger side but theres like 20-30wires lol
JohnySWB
Post by JohnySWB »
Ill double check with my Paj, in case I have put you crook some how.
I was going on my gray haired memory on this. Other than wire colour all is still correct.
Will post latter tonight iether way to let you know.
WHOOPS
Post by WHOOPS »
Right, I dont have a white cable with blue rings? they all colours and they have silver prints on them?
but awesome thanks for double checking :)
JohnySWB
Post by JohnySWB »
I'm sure glad I checked for you as I have to confess I have got the colour of the wire wrong.
But no more guess work I found on my vehicle drivers side I have cut the yellow wire with white stripe and with the silver paint rings around it.
Yeah I couldn't remember that many wires.There is a hell of lot of them.
But this info should put you right. My Paj is a 91 V6 manual.I don't know what yours is but I hope the info holds good for you.
Cheers John.
WHOOPS
Post by WHOOPS »
Haha cut cable and nothing bugger
JohnySWB
Post by JohnySWB »
"WHOOPS" Haha cut cable and nothing bugger
You wanted too stop the height adjust from going down when the vehicle exceeds, if I remember about 80 kph.
Just to check with you it was a yellow wire with a thin white stripe as opposed to a white wire with a thin yellow stripe.
Crikey don't know what to say really. Got me buggered except Mitsi must of changed the wire colour code in your model. I see you have a 3.5 shorty. mmmm
Sorry that I can't help
WHOOPS
Post by WHOOPS »
hehe yup! was the correct cable and mine drops down around 40ish km/h
but thats ok :) will try the other way
FORGE1
Post by FORGE1 »
Sorry to thread jack but is this standard on all Pajero's?
CLUMZ1
Post by CLUMZ1 »
Nope (if you're referring to adjustable height)
FORGE1
Post by FORGE1 »
Thought so, I have owned 3 pajero's and never see anything with adjustable height only the adjustable suspension dampner (Hard, Medium, Soft)
Return to “Mitsubishi”
