Diff Ratios
For all Suzuki related topics
churchill
Re: Diff Ratios
Post by churchill »
Hey man, I've only seen 5.125 and higher over here. Nothing that low but I have heard of the elusive ratios your after, just never seen anything for sale.
nivaman
Re: Diff Ratios
Post by nivaman »
Did the long wheel base Vitara's come out with 4.6 ratio diffs?.
strx7
Re: Diff Ratios
Post by strx7 »
Escudo and Vitara both manual and auto with G16A 16V engines had 5.125 diffs
the 3dr G16A 8V autos which didn't have overdrive had 4.625s in them
there are some of the later G16A 16V autos which got the 4 speed + OD auto in them which had 4.875's in them
nivaman
Re: Diff Ratios
Post by nivaman »
SUZUKI MOTOR CORPORATION JAPAN
TYPE E-TA01W-879241
ENGINE G16A 1590cc
COLOUR ODG C13
SHXR-SD4
ENGINE NUMBER (blank)
Can anyone tell from this what ratio diffs it has?.
strx7
Re: Diff Ratios
Post by strx7 »
being TA01-8##### something i'd say its a 1995-1997 vintage. if its manual its 5.125, if its auto it could be either 4.875 or 5.125
nivaman
Re: Diff Ratios
Post by nivaman »
No idea on year but its a swb automatic if thats any help?.
strx7
Re: Diff Ratios
Post by strx7 »
if its 16V it should be 5.125 but there is no gurantees
nivaman
Re: Diff Ratios
Post by nivaman »
Think the diffs i have are 5.1 as 5 turns of the input to one turn of the ring gear, is this correct?.
zukmeista
Re: Diff Ratios
Post by zukmeista »
Sounds about right.
strx7
Re: Diff Ratios
Post by strx7 »
nivaman wrote:Think the diffs i have are 5.1 as 5 turns of the input to one turn of the ring gear, is this correct?.
they are either 4.875 or 5.125 as 1 is just shy of 5 turns the other is just over 5 turns.
Return to “Suzuki”
