KZJ78 Diff
Henry
KZJ78 Diff
Post by Henry »
Hi
I have a KZJ78 with a 4.3 limited slip diff in the rear. I am looking at putting a 4.3 diff with a Lock-Right diff in.
I understand the Lock-Right can't be installed in a carrier with the limited slip.
My question is a 2 spider or a 4 spider diff stronger? I have been told a 2 spider is stronger....
Will they both fit my truck?
Thanks
tomsoffroad
Flopsie
Re: KZJ78 Diff
Post by tomsoffroad »
4 spider is the one you want, but I'm pretty sure you can get a Lokrite to suit an lsd
tow99
Re: KZJ78 Diff
Post by tow99 »
could you fit the lsd to the front and use the open carrier for the lockright in the rear?
Smurf
Re: KZJ78 Diff
Post by Smurf »
tow99 wrote:could you fit the lsd to the front and use the open carrier for the lockright in the rear?
No, As the front runs a hi pinion diff
Henry
Re: KZJ78 Diff
Post by Henry »
Hi
It already has a Lock-Right in the front so all set there....
kbjj
Re: KZJ78 Diff
Post by kbjj »
Lsd centre will fit a hi pinion, I've done it
Jeremy
