Hi Guys & Gals
I am after a factory toyota winch off a 80 series, doesnt need to go as only after the housing on the motor so if anyone can help me out and wants some extra cash that would be great, I would prefer a non working one if I could but what evers about in the Christchurch area.
Thanks
Jeremy
factory toyota winch wanted
Re: factory toyota winch wanted
thats bloddy expensive i brought mine for $500
I thought so to but i payed 16k with a free truck
. but have just read his full post doh. sorry only got half way though and remembered seeing one this morning .
Cheers, yeah it is a bit more than I want to pay, my winch is fine but the bearing housing on the front of the motor crapped itself. I think If I wasnt able to fix it I would proberly replace it with an aftermarket winch.
Thanks
Thanks
I have a 24 volt motor for one - not sure if that's any help, not sure which parts are interchangeable, but they do look different.
Thanks, I will check up and see if they are the same motor, will pm you if all good! Thanks mate
Here is the difference in length and look between the 12v low mount and the 24v high mount motor. Its a good inch longer. The 12 volt high mount motors (not shown here) look like the 24 volt motor, they may be shorter but have the same style and look as opposed to the 12v low mount motor.
Cheers for that, pic def made it easy! your very right, its totally different.
Thanks any way tho!
Thanks any way tho!
I would be interested in taking the motor with the damaged front off your hands rather than turfing it out. Cheers....
NJV6 wrote:I would be interested in taking the motor with the damaged front off your hands rather than turfing it out. Cheers....
hi glen
i be keen on buying the 24volt motor for a spare for mine, mine just been done up by stan,but always good to have a spare
cheers vince
I will let ya know, my plan is to repair it at the moment as goes fine apart from that, but if I have no joy its yours
