Manual locking hubs terrano Help
Posted: Thu Aug 02, 2012 7:08 pm
by joshpom
Hi planning on buyin and fitting manual hubs to my terrano I this weekend, is there anything I should know or anything I need to do myself, cheers:)
Re: Manual locking hubs terrano Help
Posted: Thu Aug 02, 2012 7:13 pm
by sibainmud
Two different spline counts; 27 for 86 through 94 and 31 (same as Safari) for 95 on. Some of the hubs have an interferance with the thrust washer base. You have to grind the lip back to get them to clear. Other than that, quite easy. Pays to check wheel bearings for play at the same time as it is easy to adjust while it is all apart
Posted: Thu Aug 02, 2012 7:17 pm
by joshpom
Thanks for that! Hopefully all will go well on the day, will it be obvious what I'm suppose to grind if I can't get them out? Cheers
Posted: Thu Aug 02, 2012 7:44 pm
by sibainmud
This cup looking part is what you MAY have to grind.
