i have more compression than i should
4d56 blow by but good compression
wildplumdx
so my 4d56 has massive blow by as much as the dipstick pops up and if you take the oil cap off it sounds almost like a car exhaust spiting oil etc, but i have 420psi over all cylinders at 10 cranks? and the factory specs i could find say 384psi but not sure what cranks...
Re: 4d56 blow by but good compression
No idea about the mitsi motors (least thats what I think I remember this is
but...
Have you got a blocked crank case breather? Wouldn't take much to lift the dipstick out if thats the case. And I've not run a motor without the oil cap on haha. makes a mess but you could be hearing poor valve clearances or similar with the lid off? Could see what a top tune did for it?
If you can't figure it out a leak down test may give you more info.
but...
