take away this
Note the good old kiwi jackstands...
to this
add this
and these
and longer (note where the stock arms were hitting at full extension)
and end up with...
Not all without problems, I had to space the upper arm bumpstops up 10mm or the cv's bound up at full extension. I may look into dropping the diff a little too. The shocks are just short enough and will bottom at around 10mm of bumpstop compression. I may have to mod the upper mounts for a bit safer clearance, tho the Rancho's have pretty good internal stops. We'll see.
Overall tho, it now sits level with a bit of droop still available, which was the plan after all.
