4-5th Aug
Posted: Sat Aug 04, 2012 12:41 pm
by yael
Decided wipers were to much of a job to tackle by my self so decided to sand and repaint my bonnet As all the clear cote was pealing... And yes it is a westie paint job.. Gotta love the rattle can!
Re: 4-5th Aug
Posted: Sat Aug 04, 2012 4:38 pm
by coxsy
went to the workshop started to build engine stand for my $75 TD 4.2, james carried on making his pipe front guards
Re: 4-5th Aug
Posted: Sat Aug 04, 2012 4:49 pm
by Pedro
Cleaned the rover from last weekend, figured out the front air locker is bleeding air into diff and pissing out diff breather. but still works at present so fuk it, it can wait.
Pedro
Re: 4-5th Aug
Posted: Sat Aug 04, 2012 5:50 pm
by Gnarly Dude
Went for a quick whirl on cecil rd just to get the truck dirty and made some brackets for my UHF.
Re: 4-5th Aug
Posted: Sun Aug 05, 2012 6:25 pm
by MK1TNA
Pulled my rear leaves out, disassembled them cleaned them up with a lick of paint and reassembled them with heaps of grease minus the extra thick leaf that had been added at some stage and now they actually do what there suposed to do and no more jarring my back over every bump
Re: 4-5th Aug
Posted: Sun Aug 05, 2012 7:28 pm
by tweake
RB_FIEND wrote:used the standard dump pipe flange lol i couldn't be arsed sussing out getting one cut . shes a little rough but made a huge difference !!!!!
be interesting to see how that welding onto the cast iron lasts.
Re: 4-5th Aug
Posted: Sun Aug 05, 2012 7:41 pm
by Pedro
Pedro wrote:Cleaned the rover from last weekend, figured out the front air locker is bleeding air into diff and pissing out diff breather. but still works at present so fuk it, it can wait.
Pedro
waiting over, ripped diff out and caught the copper tube and broke it off, so out to a mates place and modify it to 3/16 nickel bundy, modified the air fitting to suit, did a air test before putting back together, air is pissing out from inside the locker, so pull that apart, it appears the "bonded seal" is fuked, be interesting to see if arb parts fit the chinese locker
pull bead lock apart to fix stud holes that got flogged out when the rim came loose. Gonna mig them up and redrill
pedro
Re: 4-5th Aug
Posted: Sun Aug 05, 2012 8:39 pm
by sig
not so much a 4wd weekend but used my 4wd quad all weekend and went on a hunting trip to the wairarapa .arrived friday morn to rain and wind .decided to go for a ride around the farm so the manager could show us where we could and couldn't go .managed to hit a few goats on the tour ,my best was a couple of 360 mtr shots with my 308.over the weekend one of the boys had a new rifle to play with( tikka t3 tactical in 300WM) and pulled off a 570 and a 650 mtr shot at a couple of goats. we totaled about 20 goats and a red hind to take home.cant wait to do it again
Re: 4-5th Aug
Posted: Mon Aug 06, 2012 5:57 pm
by tweake
RB_FIEND wrote:tweake wrote:RB_FIEND wrote:used the standard dump pipe flange lol i couldn't be arsed sussing out getting one cut . shes a little rough but made a huge difference !!!!!
iv welded externals onto many cast manifolds in the past and never had any problems . the trick is to preheat the cast so that when you weld to it it doesn't super heat a concentrated area causing it to form hair line cracks as it rapidly cools down.
excellent. good to know
Re: 4-5th Aug
Posted: Mon Aug 06, 2012 6:13 pm
by taz01
Re: 4-5th Aug
Posted: Mon Aug 06, 2012 6:48 pm
by Tarmac
iv welded externals onto many cast manifolds in the past and never had any problems . the trick is to preheat the cast so that when you weld to it it doesn't super heat a concentrated area causing it to form hair line cracks as it rapidly cools down.[/quote]
[/quote]
Yup preheats the key and either use "super cast" sticks all round or lay down beads on both parent matierals and finish with 316 s/s sitcks. One aera I will reccomend busting out the stick welder for better results
Re: 4-5th Aug
Posted: Tue Aug 07, 2012 4:39 pm
by Gnarly Dude
Sunday- On the Cecil rd trip the winch wouldn't go so down at electricians, does anyone know anybody good in the Rotorua region who would be suitable for refurbishing externals of the winch as she's pretty shagged.
