Up for sale is my trusted safari TD42 non turbo manual
Has 2" lift kit
All diff, g/box, engine, brake and clutch fluids all done
New Radiator ( was changed due to some asshole at radiator shop saying it was blocked due to the weight of it, after i sweated tanks off found it was mint )
New coolant, front diff swivel hubs seals done, 1 was leaking so did both (kit was fooking expensive )
15 x 8.5 mags with 31 inch firestones
Interior very tidy exterior has usual clear coat missing on drivers door and flares, does not have rusted rear windows
HID spotlights, 10,500lb winch with rope
Cant find any rust in it, not lomg had clean sheet wof as with the ones prior
Uses no oil, does not drip oil, bloody cheap to run usually gets 10km/litre
New clutch plate, pressure plate and machined flywheel september last year
Has extractors
1989 SWB Safari for sale...SOLD
Re: 1989 SWB Safari for sale
pmd you
Safari has been sold
I am looking for another project, what is for sale out there ??
tga_4x4 wrote:Safari has been sold
hhhmmmm thought you were moving to oz
Depends on how much you want to spend...
muskie wrote:tga_4x4 wrote:Safari has been sold
Correct...its not for me
tgaguy1 wrote:tga_4x4 wrote:Safari has been sold
depends on what it is i guess, i think his budget tops at 8k
