Hey all,
I can't find any literature on how to change etc but the diagrams in the manual show its held in by a circlip. Is it a simple case of taking the circlit out and the bearing will follow or does the gbox case need to be split?
td42 engine.
Grant
Input shaft bearing safari gearbox
Re: Input shaft bearing safari gearbox
yes needs to be split and a rebuilder shop is best place for a box to be rebuilt by the manual i have
. and where mine was looked too
bugger
Not even sure if that's the problem and my money pit is empty so I may just have to perservere a wee bit longer with fingers crossed
Thanks Coxsy
Thanks Coxsy
