I bought a compression tester and checked each cylinder. they were all reading within 20psi of each other. But the reading was like 520psi average.
I that to high or did I a Crank to long?
What compression should you get for td27T
Re: What compression should you get for td27T
the manual says 427psi standard.
maybe cranking rpm was a bit high? or head has been skimmed ??
- rangimotors
engine hot or cold?
