kickdown on automatic transmission
Posted: Fri Aug 10, 2012 7:34 am
by waypa
Having trouble with my auto transmission. Cruising down the motorway at 80ks put foot hard to floorboard to pass. Truck has no power, just slowly picks up speed. However, when I flick the overdrive off it goes like a rocket. It would appear that it is not kicking down. Recently had secondhand TCS control fitted. Any ideas what could be wrong? Technician says not likely to be control switch but some other switch.
Re: kickdown on automatic transmission
Posted: Fri Aug 10, 2012 11:22 am
by pjb
What model?
Posted: Fri Aug 10, 2012 7:59 pm
by waypa
sorry 2.8 D CHALLENGER 1996 A340H toyota box
Posted: Mon Aug 13, 2012 8:42 am
by pjb
Hmm, not my area of expertise... Would have guessed throttle position sensor maybe? Those autos are electronic control, so presume trans computer uses throttle position as one of the inputs.
Posted: Mon Aug 13, 2012 9:02 am
by kbushnz
Yup no kick down cable....on those ones..
There sometimes is a cable going to box but its for pressure modulation...
ECU controlled....
My guess is you need to adjust TPS sensor.
