fj45 rat rod (ish)
fj45 rat rod (ish)
Dirty dogs rat rod thread (and some others) got me thinking about my rapidly approaching midlife crisis and the need to plan for its arrival. So I started looking for a project. I was thinking of an old yank tank but parts etc was going to be apain so I thought why not something different like a jap truck available in NZ and make it into a rod.
Okay so the projest is just an idea at the moment and I want to flesh out some ideas before I proceed.
The idea is a fj40 cab/tray chopped to lower the roof with a bent 8 (maybe diesel for laughs) and an auto driving some large rubber at the rear, with a simple axle up front (no longer 4wd). All lowered of course.
Now i realise this is going to be shunned by the american/english vehicles only types, but I like the idea of being slightly different (parts will be easier to get too as a bonus) and being slightly contravertial is a bonus.
If its build up from bits of different vehicles how hard is it to cert?
Am I mental and should i seek professional help or is this doable?
end result is something like this:
http://www.google.co.nz/imgres?imgurl=h ... EwAg&dur=0
I found some pics of an old fj40 rat rod at a SEMA show (link above) and now the idea has really taken root (even the missus said it looked cool) so anyone got a buggered 40 series cab chassis laying around, no engine or trans needed (going bent 8 and auto)?
Re: fj40 rat rod
Of course maybe a really contavertial one would be a lil zuk (lj50) rat rod running a 12a rotory. Now that would be even more of an extended finger to the establishment...
Re: fj40 rat rod
Heath wrote:end result is something like this:
to me that isnt really a rat rod its way to shinyyyy not enough rust
Re: fj40 rat rod
Yeah but the idea is cool and if I decided to "up grade" then bung on some bling and paint...
This one is cool too.
http://www.killbillet.com/attachment.ph ... 1330911541
Re: fj40 rat rod
Like the top one but not the tray.
I figure a rolling lux 2wd chassis (c/w steering, cab mounted brake bits and fuel tank) with a cab mounted and the roof dropped a few inches, fenders etc mounted up, with an old school chevy tray (graft the toyota raised metal work from tailgate on the chev tailgate), or perhaps just a normal (smaller) tray so I can actually use it for carting stuff. Small block and auto trans running to the rear only (no 4wd here).
Unless of course I would be better just dropping the std cruiser chassis down and modifying the front end (not often someone suggests doing an IFS front on SASed chassis).
Briefly discussed my idea with a guy at work and he suggested not mentioning its a jappa or a rat rod style when I am at meets etc as the local dudes arent too keen on either.
Of course if the wife keeps on suggesting that I have to sell stuff before starting this project I may have to get thinking.
I might miss her though...
Re: fj40 rat rod
"Of course if the wife keeps on suggesting that I have to sell stuff before starting this project I may have to get thinking.
I might miss her though..." you talkin bout the wife?
Utes are v cool but I liked the train of thought with the middle photo/ not that one itself, but possibly a long to mwb with a chopped roof n tubs. I wld assume you find somthin complete and like you say IFS it, plus 5spd rwd.. lockrite... 1uz.... 8throttle bodies
then your mates will know its not made in USA when it sings
Nissan also make a good v8, 4.5 I think
Re: fj40 rat rod
the vh41 and vh45's look good, plus they will fit to a z32 fairlady flywheel, so arnt hard to match up to a gearbox.
i dont know how true this is but ive been told the 300zx automatics are the same as the v6 terrano autos, so youve even got an option for 4wd.
if the front driveshaft is on the wrong side, just use a safari transfer case as they bolt on (well, essential, just need to trim shaft, i suggest use a space aswell of 20mm and 20mm off the shaft)
love how interchangeable the nissan stuff is, although it would be a shame to have it badged as a toyota when it has nissan gear....
Re: fj40 rat rod
Dirtydog wrote:the vh41 and vh45's look good, plus they will fit to a z32 fairlady flywheel, so arnt hard to match up to a gearbox.
What a half breed frankenstein monster........Hmmmm.
- KIWI_TERRANO
Re: fj40 rat rod
Haveyou seen the one tim allan? The fella off that show home improvement has
Its a bloody nice fj with v8 lowered etc
Re: fj40 rat rod
Heath wrote:Dirtydog wrote:the vh41 and vh45's look good, plus they will fit to a z32 fairlady flywheel, so arnt hard to match up to a gearbox.
Thats nissan for ya mate
Re: fj40 rat rod
Still searching the web and found a link to this tow truck rat rod.
Rough but still a cool concept...
I guess thats the essence of a rat rod.
http://ratrodtrends.blogspot.co.nz/2012 ... ecker.html
Re: fj40 rat rod
It seems that 2wd lux chassis are quite expensive (and so are the donor vehicles) so I wonder if I could use a hiace van for the donor (chassis,steering gear and brakes etc)?
Is the running gear the same?
Re: fj40 rat rod
y not get a suzuki chassis, i had a look at one today, and they seem like a great candidate, plus its not hard to put hilux axles under there if ya need it.
Re: fj40 rat rod
Heath wrote:It seems that 2wd lux chassis are quite expensive (and so are the donor vehicles) so I wonder if I could use a hiace van for the donor (chassis,steering gear and brakes etc)?
I don't think Hiaces run a separate chassis
85 Hilux single cab
02 Grand Vitara
02 Grand Vitara
Re: fj40 rat rod
try this fella? http://www.trademe.co.nz/motors/car-par ... 696155.htm
This could also do the trick: http://www.trademe.co.nz/motors/car-par ... 511298.htm
Even this... comes with an engine... http://www.trademe.co.nz/motors/car-par ... 013793.htm
or tell pick a part you will take a chassis off their hands for a few hundy after they are done? plenty of utes through there... Navara or Rodeo 2wd would likely work too...
anyway enough from me... hurry up and build this
Re: fj40 rat rod
Got my eye on a possible 45, just got to sort the price and if its still for sale...
Wifey is having second thoughts and is worried I am going to fill the yard up with wrecks.
Pickapart might be a go. Will drop in to see what they have and leave a wish list with them.
- niblik
- Sausage Shack
Re: fj40 rat rod
Hi Heath. Tried pm'in classiccruiserspares? He's local to you and might be a goer for ya.
Re: fj40 rat rod
Re: fj40 rat rod
Tarmac wrote:1uz.... 8throttle bodiesthen your mates will know its not made in USA when it sings
That would be mean
[youtube]http://www.youtube.com/watch?v=Ba8sT2BQ4uc[/youtube]
Shame the ITB setup costs more than the rest of the motor.
I say go with a Japanese V8 for a point of difference. There are more than enough 40s with SBCs in the world (and that coming from someone that owns one).
Re: fj40 rat rod
Yeah but because SBC's are so prominent parts are easy to source. A tojo bent8 would be good though for that point of difference.
Re: fj40 rat rod
Maybe a simple turboed 6 would suffice.
Nah.
Nah.
Re: fj40 rat rod
Something a little different, but think of this; slicks on and 1/4 mile drags; put the 35's on it, jack the shocks up and you have a rock crawler? No?
http://www.youtube.com/watch?v=Lh3LhIT02ho
Ph 0212078472
Ph 0212078472
Re: fj40 rat rod
kiwipete wrote:Something a little different, but think of this; slicks on and 1/4 mile drags; put the 35's on it, jack the shocks up and you have a rock crawler? No?
I like that wagon. Not quite my cup of tea but cool nonetheless.
I like the idea of airbags to alter height from low to go. Still want a road car not 4by but I havent completely decided against something with a transfer case.
- MNC
Re: fj40 rat rod
Ohhhh... damn, me likely.
Big Rubber, Big cubes, Big flex, and a sexy old body - she's got it all
Re: fj40 rat rod
i heard somewhere that hot rodders like to use 2wd L200 chassis as a basis for a rod mainly because they have the sterring box on the outside of the chassis rail allows more room for engine
my 4wd is not a truck
Re: fj40 rat rod
MNC wrote:kiwipete wrote:Something a little different, but think of this; slicks on and 1/4 mile drags; put the 35's on it, jack the shocks up and you have a rock crawler? No?
Grunt n curves got me too
Ph 0212078472
Ph 0212078472
Re: fj40 rat rod
Anyone got a chevy small block for sale? Nothing flash but in reasonable condition would be great, although a simple rebuild wouldnt scare me as long as the price is right.
Heath
Oh yeah and a transmission too would be nice, but not too keen on fiddling with this - autos scare me...
And a rolling 2wd ute chassis (mitzy or tojo or what have you - even a failed project I can resurect/restart would be good) with rego on hold even better,
And of course a cab, guards, bonnet and front of a fj/bj45 (basically all of a 45 series. The tray can come later unless some one has an old chev or ford wellside that I can "butcher" (add tojo mane on tailgate).
Heath
Re: fj40 rat rod
Heath wrote:Anyone got a chevy small block for sale? Nothing flash but in reasonable condition would be great, although a simple rebuild wouldnt scare me as long as the price is right.![]()
this joker in Tauranga's been bringing in a lot of 350's complete with all accessories and selling them off at $1351 each, some old 2 piece main seal some later one piece seal and some TBI, not alot of 350s in his listings at the moment but theres usually a pile of them
http://www.trademe.co.nz/Members/Listin ... ber=869484
Re: fj40 rat rod
"Shame the ITB setup costs more than the rest of the motor."
Cant be that bad, 2 sets of silvertop quads 300, 2.somethin meters of 60x12 flat ally ?, some ally tube, possibly a home made press former to shape to ports, many hours of shaggin round
, then tying to make it all wk - priceless
