TD42 and TD27 fan blades are they the same ??
Posted: Mon Aug 20, 2012 6:43 pm
by tga_4x4
Are they the same ??
I need to replace the fan on a TD42 and looking around they differ in price so much, some one told me the RB series and TD27 fan blades are identical
Any one in the know ??
Re: TD42 and TD27 fan blades are they the same ??
Posted: Mon Aug 20, 2012 8:59 pm
by sibainmud
TD27 have 2 different PCD's for the fans. I have 2 near new one's here but are the wrong ones to fit my TD27t :( Looking for one too as the cracks are getting bigger. Might have to buy a new one off Trade Me as i see them come up all the time.
Posted: Mon Aug 20, 2012 9:09 pm
by Crash bandicoot
I think you will find you want the fan from an RD28 or SD33.
as the water pump configuration will be more similar in nature then that of the petrol powered blocks of RB and VGand 4 cyl diesel blocks. that is if you are changing the whole hub too.
Also i note the part numbers for the TD27 used in nissan forklifts are the same too.
TD42 # 2101006J29
TD27 # 210100F002
Posted: Mon Aug 20, 2012 9:26 pm
by tga_4x4
Crash bandicoot wrote:I think you will find you want the fan from an RD28 or SD33.
TD42 # 2101006J29
TD27 # 210100F002
Hub is okay but the perverbial cracks are appearing
Posted: Tue Aug 21, 2012 8:59 am
by FORGE1
On my brother n laws safari his one stuffed out and we used one from a RB25 it worked until he got a new one about 6months later. He bolted the whole lot on hub and blades.
