16.5" rims are they around?
muddyplumber
Spring Free
Post by muddyplumber »
Found a pretty cheap set of 36x14.5(but from what I've read they maybe 15.5" wide) mickey Thompson baja belted tires only problem is they have 16.5" centers.... Has anyone seen or no the best place to go,if rims are gonna cost me n arm n a leg I won't bother with them.but just thought I'd try and get as much info as I can
rich
mud_slinger
Re: 16.5" rims are they around?
Post by mud_slinger »
good luck with that :lol: um maybe truck rims but i dont know if that stud pattern or stud holes would work
needs more curry
0272593533
sig
Jeep Jeep
Post by sig »
chevy ambulances have 16.5 rims BUT are 8 stud ie dana 60 ! maybe .
rokhound
Post by rokhound »
Yep they are round (wouldn't work if they weren't :wink: :mrgreen: )
A real bitch to find. Go out to Elite wheels and get some made, this is the fastest and easist option. I fluked some alloy ones when I got the 39.5's, but I wouldn't look at this size tyre again because of the dramas I had.
mudlva
Post by mudlva »
usa ran that size rim
rokhound
Post by rokhound »
Sure did. There used to be lots of BFG,s around that were that size, but most of them have been weeded out now I think.
muddyplumber
Spring Free
Thanks for all the info,yea will go visit Elite in the next few days n see what they worth
mudlva
Post by mudlva »
muddyplumber wrote:Thanks for all the info,yea will go visit Elite in the next few days n see what they worth
unless the tyres are real cheap i would be careful as once the tyres are dead then getting more tyres to suit your rims may end up being quite a challenge
rokhound
Post by rokhound »
Dead right, but the wheels are the cheapest part as a rule, so no issues with ditching them when tyres are done
muddyplumber
Spring Free
I can see why they've been sitting in this guys shed for ages,rims are the hard bit,can not see it being worth it as the tires are half worn
Sleepn
Post by Sleepn »
I noticed this last night, could be worth a shot and see if he will sell the 16.5" set of rims he has separately?
http://www.trademe.co.nz/motors/used-ca ... 952698.htm
muddyplumber
Spring Free
Thanks man just flicked him an email
tomsoffroad
Flopsie
Post by tomsoffroad »
Could be wrong but I think 16.5" rims have a different bead which relies more on pressure to keep it seated? :?
De-Ranged
Post by De-Ranged »
it is the same size that is used by the american army with there humvee's also a good source for tyres (depending on freight)
As for the different bead that will depend on the tyre and rim profile most common for 4wd is the "jj" at the end of the rim code if it is anything different run a search online the profiles are all listed
Filthy4x4
Post by Filthy4x4 »
tomsoffroad wrote:Could be wrong but I think 16.5" rims have a different bead which relies more on pressure to keep it seated? :?
Yeah your spot on there. Flatmates chev got a hole in the tyre (36x14.5x16.5 Mickey thompsons), it went flat and just fell off the bead :lol: had to use a bead blaster to get it back on. Mate at the tyre shop said the 16.5s were renowned for doing that.
027 MUD GEAR - (027 683 4327)
Check our facebook:
aroma
Post by aroma »
some ag rims 16.5 try sparex, bareco or trs all in chch first 2 have websites
Tarmac
Post by Tarmac »
Jeep? rims - sure I've seen them FS but then offset n pcd problems. Them tyres must bk farkn cheap for the hastle
Return to “Tyres”
