how strong are rugger diffs?
For all Daihatsu related topics.
tuk
Post by tuk »
Hi
Im going to do the holden 3.8 conversion on my 1990 rugger 2.8dt. my mates are running the same conversion (in a suzuki and bighorn) with lux diffs and both seem to be having front diff troubles.
Has anyone run a 3.8 v6 with daihatsu diffs and did they handle it?
Crash bandicoot
Re: how strong are rugger diffs?
Post by Crash bandicoot »
just found this on a uk forum....surprisingly the diahatsu axles are heavier then a 70 series toyota landcruiser.
the diahatsu shaft is on the left
you will always have front diff issues with bigger power i think the rocky/rugger etc is 95 horsepower so it's to be expected.
tuk
Post by tuk »
cheers for the info, i already have the motor and box so i guess il see what happens.
mudlva
Post by mudlva »
I was told that daihatsu used hylux specs on there earlier vehicles and now of a lad who used hylux bits on his rugger being daihutsu and toyota are linked then it stands that there would be componant shareing because thats how toyota built all there vehicles
A v6commy will give hylux gear greive aswell more so if running lockers
crazyclark31
Post by crazyclark31 »
dunno how they would handle a v6 but had a very tricked up 2lt in my blizzard and never blew a diff/cv with 33s and chains. Even the guy who bought it off me who was a real idiot behind the wheel didn't break it.
callum007
Post by callum007 »
I ran 35" silverstones on standard blizzard (f70) running gear with a holden 202 never had an issue. swapped it all out for hilux running gear. broke 2 cv's on my rear axles in 2 hours.. mind you I swapped the 202 for chev 350..
Give it a shot, only greif will be getting spares when you break stuff. I had all sorts of dramas with parts
callum007 wrote:Give it a shot, only greif will be getting spares when you break stuff. I had all sorts of dramas with parts
yep thats what I was sort of thinking :D
2roky
Post by 2roky »
i snapped a front a axle running 33 monoform mongrels, mind you the diff that that axle came from was in a fairly heavy crash so it may have been weakened. other than that i never had a problem and i was running a slippery in the front end as well as the rear
Return to “Daihatsu”
