Rolled hilux engine help
AngusM
Post by AngusM »
Gday everyone. I managed to roll my hilux (2.8D) onto its left hand side- managed to turn the engine off. Left it to sit for an hour or so after I got it upright, and checked that it turned over by turning the starter motor/belt and it started alright.
It feels fine to drive, doesn't over heat, but there is oil in the air filter.
Is it probable that oil got into the cylinders and damaged the engine?
tomsoffroad
Flopsie
Re: Rolled hilux engine help
Post by tomsoffroad »
Probably ran out the engine breather. Replace the filter, she'll be sweet :wink:
Crash bandicoot
Post by Crash bandicoot »
diesels burn oil. if it still runs fine then there obviously wasn't enough oil to cause compression lock.
change the filter. its a hilux after all. look what they did to it on topgear.
