can anyone tell me for sure which oil goes in a pto winch (one off a safari) i've had a couple of people tell me one type and another couple tell me another.
they have a bronze gear so needs to be the right type
PTO winch oil
Re: PTO winch oil
I use Elf SP680 ,its an industrial gear oil designed for worm drives and bronze gears ..
Re: PTO winch oil
http://www.adl.co.nz/Parts/40293/
its not cheap and you need a sludge gun to get the shit in its almost as thick as grease
Re: PTO winch oil
Its cheaper to buy direct from Elf in Manukau... Cash sale...
And its a 5L container and you only use about 1 1/2 cup fulls.
But I see you are in Nelson.... So there goes that idea...
Re: PTO winch oil
i'm sure someone will sell it around here, cheers.
Re: PTO winch oil
A gear oil that doesn't have EP in it, we've used all sorts and EP limits the winch life to about zero.
Re: PTO winch oil
ah ok cheers
just found this on trademe, this guy is keen, works out at $50 bucks a litre if you use buy now
http://www.trademe.co.nz/motors/car-par ... 635206.htm
Re: PTO winch oil
y60 safari driver wrote:ah ok cheers
just found this on trademe, this guy is keen, works out at $50 bucks a litre if you use buy now![]()
Hahhah what a rip.... But then again my $45 dollar 5L bottle is now worth over $200 .... whaaaa hoooo.
