Prize for best answer
Grant
Want2Retire wrote:Cheers ice. Now for silly question. How would I know, or discover the grade of the original bolts?
Want2Retire wrote:Thanks ice,
Note to self...need to look at bolt heads from now on
Want2Retire wrote:Some complete knob-end (previous owner I guess) tried to remove the front driveshaft to tackle u-joint replacement (I guess, as there is a grinding noise only in 4wd that appears to speed up with acceleratiion only). Anyway, at the double carden joint it seems two of the 8mm? bolts that connect driveshaft to transfer case have been rounded. Can replacement bolts be easily sourced, or will any bolt of same size fit?
Grant
