1JZGTE Non VVTi motor from JZZ30 Soarer.
New Genuine Cambelt, Waterpump, Tensioner, Idler, Seals, Drive belt. (Less than 1000kms)
R151F Gearbox, Running Redline Shockproof Oil.
Autoclutch custom setup clutch. (Needs replacing as slipping, was quoted $200 for 'freshenup')
Solid Axle, Coil sprung front and rear with 2" Body Lift, and a 2" Suspension lift. (Looks like Cobra springs?)
Engine has a Fuel Pressure regulator, Custom baffled sump, Bosch 044 Fuel pump, Oil filter relocation kit, Oil Cooler, Front mount intercooler, 3" Straight through exhaust with mid muffler.
15x10" -44 Steel wheels with 35x12.5x15 Maxxis Trepadors half worn.
Have replaced front and rear pads and rotors around 2000kms ago.
Has aftermarket head deck, and 4" speakers all round. Also has a 12" sub in the rear door and an amp.
Front left hub seal needs doing, slowly leaking and as mentioned before, the clutch is slipping so will need to be replaced. Truck is pretty fast and is fairly good off road.
Will be getting more pictures done during the week.
I'm after 13,000 ono for this. Comes with factory 15x7 -20 standard wheels, Please give me a text, email or call if you're interested.
021 1000 996
jcurphey@gmail.com
