Right
Will a LSD diff head fit into a non LSD axle housing?
Will I just need to yank the axles out, Put the LSD head in and bolt it all back together?
LSD Diff
Re: LSD Diff
Yep.
Re: LSD Diff
Provided they are both "HG" type (233mm) and are the same ratios.
Easy swap over too.
Easy swap over too.
Re: LSD Diff
Check the lenght of the axles, I got caught out . Bearings were seized on my factory locker diff so to save money & time I removed axles from a spare LSD & tried to fit them into the locker diff, wouldn't fit. Compared the 2 sets long side (lsd) too short & short side too long?!
Re: LSD Diff
BogBoy wrote:Will a LSD diff head fit into a non LSD axle housing?
I had no issues doing this to mine (hg46 type)
Re: LSD Diff
mudtroll wrote:Check the lenght of the axles, I got caught out . Bearings were seized on my factory locker diff so to save money & time I removed axles from a spare LSD & tried to fit them into the locker diff, wouldn't fit. Compared the 2 sets long side (lsd) too short & short side too long?!
Centre pumpkin diff. But do check the spline count on the half shafts.
Re: LSD Diff
Hmmm ok so I did the swap....
Turns out my old head was a LSD........ So now I have a LSD axle for sale lol
Re: LSD Diff
an open diff carrier externally looks the same as a non lsd carrier, well the stronger ones do anyway.
i thought the same aswell when mine got taken out. but mine was only open, just about caught me out i though i had the wrong oil in then diff......
