Hi Guys
I am debating get a set of either 35 or 36 tyres and would like to hear og folks experinces with them on a LWB td42 n./a with standard 4.1 diffs and a 50mm lift
Thanks for any help
Looking at going to 36" tyres
- mudlva
Re: Looking at going to 36" tyres
36's will suck the power
if auto you will it
if manuel you will need to upgrade the clutch
they still would be my first choice thou
if auto you will it
- Suza
Cheers Mudlva, its a manual so that should help and cheers for the heads up on the clutch
- crazyclark31
You will be using first low heaps and will have to ride the clutch abit with 36s.
i'd be looking for some lower ratio diffsfirst then get the bigger tyres. Or turbo it
May find your tyres are rubbing on the guards alot with only 50mm of lift
- Suza
Thank you to all for your comments. After much thought I have decided to stay with my 33's for the mean time
