tote tank
3800v6lux
Newbie
Newbie
tote tank
Post by 3800v6lux »
how do i make a tote tank work in a 3800 v6 commodore engine in a hilux?
Cheers Ethan
Pedro
Re: tote tank
Post by Pedro »
you will need a return pipe and external fuel pump, pref mounted lower than the tank. from a vague memory the totes only have one pipe coming out, i would assume you want it to be removeable for refilling, you could fit a fitting into the tank for the return and put a dry break connector on that hose, so you can unplug the fuel feed, and return and remove the tank
Pedro
3800v6lux
Newbie
Newbie
Re: tote tank
Post by 3800v6lux »
thanx Pedro
