Shorty recovery rope
After a few trips where a short recovery (no snatch) rope would have been useful to get someone quickly moving again I had a plan. Got some 12mm Dynamica rope for $9.99 per m off Trademe. This stuff is rated to a breaking strain over 16000kg. Starting with a 5m length I spliced in a stainless thimble (from Cooks) at each end and ended up just over 4m long. The thimbles fit nicely on a recovery hook and I reckon this will be just the trick for those tight spots where a little persuasion is all that is needed, super light and easy to stow. Total cost just over $70. Will still keep the trusty ARB snatch strap on the back for the more serious recoveries
Re: Shorty recovery rope
Wouldn't want to do a snatch recovery with that - not a lot of stretch in a winch rope, but as you say, if you just want a light tug and a rope that packs away small.
Cleary wrote:Wouldn't want to do a snatch recovery with that - not a lot of stretch in a winch rope, but as you say, if you just want a light tug and a rope that packs away small.
a winch rope should have no stretch at all.
And yes, that dynamic should only be used for light pulls, not snatching or tugging.
- mudlva
by the time you have done that it would be easier just to go into cookes and order a 4 mtr stretchy and that way if you need to more persuasive you can with no fear of having the tow conection parting company witrh the vehicle
Lots of support on this website thats for sure..
Looks like it will be good for what you need it for, nice splicing too
mayday wrote:Lots of support on this website thats for sure..Looks like it will be good for what you need it for, nice splicing too
Ill 2nd that. good job, shure itll come in handy many a time.
Yeah definately won't be snatching with it, thought I'd made that clear in my first post. Purposefully wanted no stretch so if something did come adrift less propulsion
. This thing packs up small and is quicker to stow than my snatch strap which always seems to be twisted
. Only problem may be abrasion but will keep an eye on that or sort out some protective wrap etc.
pruggerdore
nice work. winch extensions. going to make me a 20 metre like that. got tree protectors to use for shorter ones. and genuine winch extensions.
CRAZYBUSTARD
- Bush Crasher
i just use a tree protecter for that
