Turbo muffler
Posted: Tue Sep 25, 2012 5:38 pm
by rayndeb
im doing the exhaust for my hilux turbo and wondering should i put a full size muffler in or one of those Coby style . I want it to have a nice deep note not boy racer cackle .Any advice or input I'm sure some one has done this before .I'm doing a 2.5 inch pipe out of bends . Cheers For help
Re: Turbo muffler
Posted: Tue Sep 25, 2012 8:11 pm
by slide
The turbo takes quite a bit of noise out of it. Maybe build the system with no mufflers, take for a drive and see how it goes. If its way loud, get a muffler. If its not too bad, get a coby style resonator. Won't take much to add in muffler afterwards if you route the pipe with the idea of putting one in later.
My 10cents anyways.
Nath
Re: Turbo muffler
Posted: Tue Sep 25, 2012 10:04 pm
by crazyclark31
on my turbo safari i ran a 3in pipe right through with no mufflers of any type and it was fine. Did have a bit of a drone but didn't bother us.
Re: Turbo muffler
Posted: Tue Sep 25, 2012 11:51 pm
by tweake
what hilux motor?
the L series tend to be loud as without any mufflers. a whole different ball game to the big 6 cyl's.
single 'coby' works ok tho i keep getting told it sounds like a tractor! otherwise fit two.
the other way is to fit a small coby up front and a big empty resonator at the rear (size of a main muffler but nothing in it). you can play around with a few different combo's.
Re: Turbo muffler
Posted: Wed Sep 26, 2012 9:20 am
by wax
NO muffler. All good if you dont like it then put one in later. My muffler filled with diesel soot straight away so better off taking it out
Re: Turbo muffler
Posted: Sat Sep 29, 2012 9:12 pm
by slide
Only problem with no muffler is in NZ we need one for wof...
From virm;
Exhaust system means a pipe assembly through which the engine exhaust gases pass to the atmosphere and includes some means of sound reduction such as a silencer or resonator
Re: Turbo muffler
Posted: Sun Sep 30, 2012 6:54 am
by rayndeb
Im now after a flange for a ct20 turbo to make a dump pipe .Im trying to find a full size unrestrictive muffler with straight inlet and out so i can change it without too much mod if no good
Re: Turbo muffler
Posted: Sun Sep 30, 2012 10:20 am
by jonossiksilvia
running these in my truck. no packing in them to clog up just baffles
http://www.trademe.co.nz/motors/car-par ... 281303.htmcan see inside cutaway of muffler in this link
http://www.flowmastermufflers.com/searc ... &sc3=&sc4=
Re: Turbo muffler
Posted: Sun Sep 30, 2012 8:29 pm
by rayndeb
thats the one ive got my eye on
Re: Turbo muffler
Posted: Sun Sep 30, 2012 10:44 pm
by Fakey
Those are a bit pricey. They look like the flow sound ones from Chase exhausts only painted black not silver. I've used one on each of my last two petrol cruisers. Pretty sure I only paid $80 or $90 each.
Re: Turbo muffler
Posted: Sat Oct 20, 2012 8:06 pm
by surf lux
slide wrote:Only problem with no muffler is in NZ we need one for wof...
From virm;
I put on a 3 inch straight pipe system on my hilux, 1 Kz engine,it was quiet enough to pass a vtnz Wof so I'd tend to ignore that rule as they don't care wether or not it's got a muffler long as it's quiet.
Re: Turbo muffler
Posted: Wed Oct 24, 2012 3:01 pm
by 4wddamo
ive got 2.5 of the back of the turbo with a coby on my courier td. goes thru wof no problem.
