Wheel Spacers?
brakes-shocks-lockers-etc
turoa
Pyro Junior
Wheel Spacers?
Post by turoa »
I have a problem with my rear axle, the wheels dont clear the calipers. So... where can I buy some wheel spacers? I would like to get some 25mm ones if possible to make the rover as wide as possible. Is it a good idea, or should I just buy some 10mm ones so I can clear the caliper?
Ryan
Post by Ryan »
get an engineer to make wot eva you want....
freind of mine had spacers made and it was
cheaper than buying new
oldblue
Post by oldblue »
Just remember that you must have a full nut of thread. If you went 10mm you may not have a full nut.
callum007
Post by callum007 »
ask reece.. he very helpful.. i think he going to end up making me a set..
or snake racing does them off the shelf
