Carved the hing bits from solid 4130 and the pin was machined out of 4340... set with brass bushes and grease ports, They have a swing of 30deg
I'm going to weld the "bottom" up into the front X member
I'm still going to use the rear up front spring swop as well
The idea with the hing is at full drop the spring pack gets a mean twist in it as the axle angle get worse, this should allow more drop from the springs becouse there will be no bind
An added bonus with doing this on the front is my axle now "hinges" so it will hopefully swing instead of trying to drop straight down... this swing should move the axle similar to my steering drag link reducing bump steer
There is one issue I don't know about, is the swing going to give me a change in steering eg over steer to under steer on conpression :scratch:
All I need to do is make some hinged shackles now
Cheers Reece
