Removing aircon to improve cooling
BAUSHOG
Post by BAUSHOG »
Halfway through getting my 1995 V8 discovery Aircon out.
Looking to remove the aircon radiator, keep the fans but on a switch to push some air into the radiator. Ripped the radiator out and realised thats probably worth looking into fixing up or replacing. Mud everywhere and pretty beaten up.
Anything i should look into before just ripping the aircon out? Can i just cut all the pipes and crimp them up?
Any info or input welcome!
ant-neil
Re: Removing aircon to improve cooling
Post by ant-neil »
im gonna take mine out of my V8 disco but mainly to turn into a air compressor , working on it at mo, also adding an extra trans cooler to look after the auto , just putting on top other one
Ralfie
Post by Ralfie »
BAUSHOG wrote:Halfway through getting my 1995 V8 discovery Aircon out.
Remember the air cond will have gas in it that needs to be properly removed by specialist. Most places have a mobile guy that can come and do that for you.
It you just let it go into the air it causes enviromental problems.
After that just unbolt the pipes.
Easy to remove condenser once radiator out.
Once gas is out take the belt off the pump (unless you have the later serpentine belt in which case you will need teh shorter non air cond drive belt).
jonossiksilvia
Post by jonossiksilvia »
Ralfie wrote:It you just let it go into the air it causes enviromental problems.
dont forget the fine if get caught doing it
BAUSHOG
Post by BAUSHOG »
Sounds pretty simple to do then might have to get onto it this weekend!
Could you use the compressor for other things?
Crash bandicoot
Post by Crash bandicoot »
I didn't have a choice. a rogue stick in a mud hole dealt to my air con radiator. :lol:
