how do i take off a water pump on a td27?
- stuckasguy
- Stropper
just bought a new truck and went and had some fun at the waimak any way got home and saw a puddle of water and it wouldnt start so i think iv broken the water pump and my starter motor has gone to! and ways can any one help me out by telling me how i pull the water pump out !
Re: how do i take off a water pump on a td27?
Drain radiator, remove hoses at the top, unclip the bottom part of the fan shroud and remove radiator. Loosen fan belts and remove. Unbolt fan. Unbolt water pump, bolt on new one and reassemble.
- stuckasguy
- Stropper
thanks mate was lot easyer then i thort
Just be aware there is like 6 different versions or something silly so you need to bring it in to get the right one...
- stuckasguy
- Stropper
ohh true im in chch do you live around here? or if not could i go to super cheap or repco or a 4wd shop and they would get them in??
stuckasguy wrote:ohh true im in chch do you live around here? or if not could i go to super cheap or repco or a 4wd shop and they would get them in??
Try BNT, they have them.
Ph 0212078472
Ph 0212078472
- stuckasguy
- Stropper
