disco lsd
Posted: Mon Oct 08, 2012 11:33 am
by ant-neil
any one know if there are any around
open dif is shit and dont want a locker
Re: disco lsd
Posted: Mon Oct 08, 2012 11:44 am
by turoa
No, they don't come with lsd's unless you get an aftermarket one. In which case you're better off buying an arb
Re: disco lsd
Posted: Mon Oct 08, 2012 11:56 am
by LR90NZ
Aftermarket Limited Slip Diffs are readily available but do come at a cost.
Standard diffs heads are upgradeable to stronger 4-pinion centres (about $250 for second hand centres) if you are looking for stronger diffs.
Re: disco lsd
Posted: Mon Oct 08, 2012 11:59 am
by UBZ
you could fit a Detroit Truetrac mechanical LSD
they make one for the rover diff
http://www.eaton.com/Eaton/ProductsServices/Automotive/AutomotiveAftermarket/Differentials/PCT_221471personally i think a Auto or selectable locker is much better for off road use
