rear 80 series springs wanted
Posted: Fri Oct 12, 2012 3:47 pm
by sg8380
hey im after some rear 80 series landcruiser springs to put in a ln130 surf
Thanks, Sam
Re: rear 80 series springs wanted
Posted: Fri Oct 12, 2012 6:07 pm
by Smurf
How are you going to level out the front once you have lifted the rear 4 or more inches?
Posted: Sat Oct 13, 2012 8:18 am
by rowdyrunner
Gidday i can get you a pair of them cheap if you like. PM me
Posted: Sun Oct 14, 2012 6:48 pm
by Big
got some.. pm me if needed..
Posted: Sun Oct 14, 2012 8:57 pm
by sg8380
hey ill just wind the torsion bars up in the front, my mate has just done it to his and it looks good
Posted: Tue Oct 16, 2012 8:09 pm
by evolution02
Smurf wrote:How are you going to level out the front once you have lifted the rear 4 or more inches?
Smurf says this as you can only get about 2 inches out of the torsion bars. If you wind them to far you will be against the bump stops and have no travel left
Posted: Tue Oct 16, 2012 8:22 pm
by sg8380
whats the other option i have to raise it?
Posted: Tue Oct 16, 2012 8:38 pm
by jonossiksilvia
sas but not a cheap option
Posted: Tue Oct 16, 2012 9:09 pm
by sg8380
Just wondering what an sas is? Haha
Posted: Tue Oct 16, 2012 9:12 pm
by keithal
sas is a solid axle swap
there have been a few done recently on here
have a look in Tomsoffroad thread and you will see jammysammy's surf with a prado front axle
Posted: Tue Oct 16, 2012 9:50 pm
by sg8380
What would the cheapest and easiest option be to raise it
Posted: Tue Oct 16, 2012 9:57 pm
by keithal
50mm spring lift/shocks in the rear and wind the torsions to suit
Posted: Wed Oct 17, 2012 8:12 pm
by sg8380
Do front springs off a 80 series land cruiser fit in and give it a 50 mm lift from standard height?
Posted: Wed Oct 17, 2012 8:54 pm
by Smurf
80 series fronts are a different diameter coil and don't fit. Will also lift higher than the 80 series rear.
Posted: Thu Oct 18, 2012 5:47 am
by sg8380
Ok thanks for that ill just stick to the 50mm lift springs then
