Hey guys im in the final stage of of building the rb25det and am wondering if someone has a td27 workshop manual that could look over the electrical section for me.
I need to know since the d21 td27 has no ecu where did the automatic TCU get its signals from (please no estimates need to look over wiring diagram picture). I believe it used the throttle position sensor and wires to the rpm and speedo in the gauge cluster.
Help would be great
d21 Terrano wiring help
Re: d21 Terrano wiring help
i can have a look for you and try email you the wiring diagrams?
thanks heap dirty dog, email paulducrot@hotmail.com .
Ended up wiring the megasquirt stand alone ecu into the engine which has no automatic control functions, but due to the dirty old td27 having no ecu it should be a problem just the throttle position sensor
Just looking through td27 service manual now. It doesn't however mention auto control or glow plug control grrr
However the td27 does run a ecu, inputs being temp sensor, RPM, and potentiometer (TPS on fuel pump).
Outputs are tachometer (dash), EGR solenoid valve (a), and EGR solenoid valve (b).
Would be handy to know if thats all this ECU runs, or if it controls glows/auto also.
I might have to start reading up online manuals...
Hope that bit helps you some,
Nath
Nath
awesome thanks for that information gives me a better idea of what i am in for. I am unaware that the td27 ran a ecu and during my entire rebuild i am yet to stumble apon the ecu, does anyone know where it is? i know the tcm is behind rear right speaker in under plastic side panel but never seen ecu.
Managed to find a wiring diagram, at control chart and a Chart that shows what the speed control deive does/connects to, no wire codes though
But hope this is what your looking for.
You should receive it soon.
thanks alot for that i received it and will be enough to try get my head around how this all works, very interesting how its wired to the actuator. Thanks again i greatly appreciate it
Service manual shows ecu in behind lr interior panel, but thats for 3door, not sure about 5door ??
Pretty sure its same for 5 door.
But im just glad i could help, cant wait to see it going
