Surf 1989 ln130 rev counter not working?
sg8380
Post by sg8380 »
Hey in my surf the rev counter has just stopped working just wanting to know if any one has had this problem before and how they fixed it, thanks
Sam
1989 Surf ln130 2lt
31 maxxis buckshots
2 inch suspension lift
jagni401
Re: Surf 1989 ln130 rev counter not working?
Post by jagni401 »
Cable has probably broken. Poke your head underneath on the driver's side and you will see where the cable goes into the gearbox. Just unscrew it and check to see whether it is broken or not.
Smurf
Post by Smurf »
jagni401 wrote:Cable has probably broken. Poke your head underneath on the driver's side and you will see where the cable goes into the gearbox. Just unscrew it and check to see whether it is broken or not.
This would be the speedo cable you are refering too.
The rev counter runs off the injector pump.
First thing I'd check is that the plug is still connected at the pump.
sg8380
Post by sg8380 »
Ok I'll check it out tonight to see if its the problem?
1989 Surf ln130 2lt
31 maxxis buckshots
jagni401
Post by jagni401 »
Haha, yep. My bad. Misread the post
sg8380
Post by sg8380 »
Hey I've tried to have a look, what colour is the injector pump plug or what would it look like( how may wires running into the plug, is it the thin green wire?
1989 Surf ln130 2lt
31 maxxis buckshots
