Surf 1989 ln130 rev counter not working?
Posted: Tue Oct 16, 2012 9:53 pm
by sg8380
Hey in my surf the rev counter has just stopped working just wanting to know if any one has had this problem before and how they fixed it, thanks
Sam
Re: Surf 1989 ln130 rev counter not working?
Posted: Tue Oct 16, 2012 9:56 pm
by jagni401
Cable has probably broken. Poke your head underneath on the driver's side and you will see where the cable goes into the gearbox. Just unscrew it and check to see whether it is broken or not.
Posted: Tue Oct 16, 2012 10:30 pm
by Smurf
jagni401 wrote:Cable has probably broken. Poke your head underneath on the driver's side and you will see where the cable goes into the gearbox. Just unscrew it and check to see whether it is broken or not.
This would be the speedo cable you are refering too.
The rev counter runs off the injector pump.
First thing I'd check is that the plug is still connected at the pump.
Posted: Wed Oct 17, 2012 8:32 am
by sg8380
Ok I'll check it out tonight to see if its the problem?
Posted: Wed Oct 17, 2012 8:38 am
by jagni401
Haha, yep. My bad. Misread the post
Posted: Wed Oct 17, 2012 5:29 pm
by sg8380
Hey I've tried to have a look, what colour is the injector pump plug or what would it look like( how may wires running into the plug, is it the thin green wire?
