Swaybar release
For all Nissan related topics
MudBum
Swaybar release
Post by MudBum »
Hi people,
Went to the local wrecker here in chch to price a factory swaybar release for the Safari.He had 4 sitting in vehicles so they looked like an item that was not so sort after. :cry: WRONG.. $400 bucks if i took it out :twisted:
A bit steep for what it is..does anyone know of 1 for sale cheaper than this :?: :?:
doddzee
Is Doddgee
Post by doddzee »
I have the complete set up (i think ill have to check tonight) you can have for $120 + freight but i think you are better off taking the hole sway bar off. The dissconect only releases one side so doesnt make as much difference as removing it all together. Try removing it and go for a drive if you dont like the way it feels then put on a release.
If yours did not come with it from factory then it may not have the mounting brackets on the chassis either.
MudBum
Post by MudBum »
Cheers Doddzee, i'll give that a try and let you know.. 8)
