Dulux overhaul
Heath
Dulux overhaul
Post by Heath »
What paint is recommended for engine block and transmission for a "dulux overhaul"?
And what prep work is required? Will be done properly later on when it's stripped down, but for now after I clean the accumulated crud off I'd like to give it a spruce up. Prefer in spray cans so touch ups and rematching colours will be easier.
Engine is steel and transmission is ali.
Cheers.
Weemsy
Re: Dulux overhaul
Post by Weemsy »
repco sell some stuff,
i think its called vht engine enamel or something like that.
we use it at work for touching stuff up after engine/trans work.
seems to be good so far
weemsy
Weemsy
Re: Dulux overhaul
Post by Weemsy »
weemsy
Heath
Re: Dulux overhaul
Post by Heath »
Bit of an echo here - LOL
Any prep required?
Weemsy
Re: Dulux overhaul
Post by Weemsy »
im not sure how i managed that :lol:
i think just clean and not flakey, then spray on
northdude
Re: Dulux overhaul
Post by northdude »
give it a good degrease and waterblast the vht engine enamel will stay on better if the engine is warm when you spray it on
Heath
Re: Dulux overhaul
Post by Heath »
Tried to clean the engine and transmission today. Tonnes of degreaser (cheap crap), some carby cleaner and simple grean.
Carby cleaner is great and works a treat (but expensive), cheap degreaser from warehouse (autohaus???) is shite, might remove a film of oil from a greasy plate but not this stuff. Cheap Supa chump degreaser seemed to work okay (but ran out), but didnt move the really stuborn stuff. Simple grean is awesome, did a better job than the others, but still couldnt get it all off. Was using a waterblaster to remove the shite and it still didnt want to shift much. Upart from the crap staining my drive that is - LOL.
Steam cleaner might shift this gunge I think, but I dont have one.
Re: Dulux overhaul
get some of that POR15 Marine clean its about 25 bucks for 1/2 a litre, its caustic based so you have to wear good gloves or you'll end up burning your fingers like someone I know :oops: Image
Heath
Re: Dulux overhaul
Post by Heath »
Is it wash up in water stuff?
I havent got anywhere but my drive to do the deed so need to wash it into the weeds ... ah ... I mean front garden. :mrgreen:
Re: Dulux overhaul
yeah its water soluble
