L200 not getting oil to the No.1 rocker
Zooker
Post by Zooker »
My old man has an 95 L200 with a 4d56t in it.
The thing used to be the most reliable ute ever.
Then the heater hose split and it got hot, then the No.1 cam lobe wore out.
We have since replaced the head and everything in it.
Now its got noisey tappets. they are adjusted correctly.
Dad thinks it not getting oil to the front of the cam.
Does anybody know what this could be??
Dad swears nothing was blocked when he put the new head on.
Cheers, Adam
Heath
Re: L200 not getting oil to the No.1 rocker
Post by Heath »
I'm picking an oilway in the block is blocked. Bad news if I am right as its tear down and rebuild time. Although it could just be the brg is not seated right and is blocking the oilway. Either way its top off for a lookseeand maybe a chemical clean of oilways.
I am guessing of course... :mrgreen:
Zooker
Post by Zooker »
Its still pumping alot of oil to the head.
Only its not getting enough into the rocker shaft I think.
Its just the front rocker starving of oil, the rest are sweet as.
NJV6
Post by NJV6 »
One of the rocker caps is different to the rest, I think it is the front one, you need to take them off to check thought, I think it has an extra oil hole in the bottom, might not have gone back on the same?
Zooker
Post by Zooker »
Theres two that are slightly different. But they are numbered.
And look right.
Return to “Mitsubishi”
