hand helds. gps/uhf radio
kaney
Post by kaney »
http://www.trademe.co.nz/Electronics-ph ... 359953.htm
anyone got any ideas about these things. or would i be better to get each one seperate?
wjw
Post by wjw »
Ok, From experience, my ideal mix is:
1. Truck mount 5 Watt PRS Radio with decent aerial
2. At least one 0.5 Watt Handheld PRS Radio
3. GPS with external Antenna for truck, either built into no 1 or seperate unit
I have 1 and 2 and a hand held GPS.
Who knew Prados could fly?
callum007
Post by callum007 »
id say it was a cheap toy... bit of a gimmick really
wjw
Post by wjw »
callum007 wrote:id say it was a cheap toy... bit of a gimmick really
The truck mount version is actually pretty good, Al has one. But yes on second glance it looks a bit gimmicky :)
4WDbits
Post by 4WDbits »
Some guys love em, if everyone had one we would all know where everyone was, maybe.
Personally I use 5 watt water proof handhelds and use the charging tray to mount it in the truck, cig adapter and it never goes flat.
BrentC
Post by BrentC »
wjw wrote:Ok, From experience, my ideal mix is:
I have a gme TX3200 http://www.gme.net.nz/uhf_transceivers.html
and a couple of FlyBuys handhelds
I also have - but hardly use - as the radio part is illegal in NZ - 2 garmin Rhino 120's and 1 garmin Rhino 520 GPS Radios - you can set one up with OziAPRS on a Laptop and show on the map the other units - download their track logs etc
http://www.garmin.com/products/rino520/
albundy
Rolly Polly
Post by albundy »
Their not a cheap toy. I have the truck mount version of this and I find it quite good. It has waypoints trip computer, etc etc and a radio range of 25kms, also all the mounted speed camera postions. It doesn't have the maps or little worm showing your track. It does give you a compass to navigate to your waypoints though. f you can afford the extra go for the truck mount and buy a cheap handheld.
A
Aaron
Post by Aaron »
I have one of these, got it from trademe for $100 second hand.
Works very well but doesnt last long on the batt if you have the gps on all the time.
If you can afford a vehicle mounted unit get one, then you dont have to worry about batterys.
Toyota 70 series cruiser, 13bt
Phone 029 454 8533
Don't bother with the cheaper 0.5w (or 0.1w) handhelds, they are crap, go for the more expensive better handhelds if you can
Return to “Tool Shed”
