1991 2.5T Diesel pajero oil leaks
Posted: Tue Oct 30, 2012 4:20 pm
Trying to eliminate oil leaks & about to pull the belts off for the 3rd time.
Im going to try get to the crank seal and harmonic balancer seals.
Does anyone know the method for the removal of the cam belts Crankshaft sproket? is a gear puller fine? Can remove the Crankshaft pulley no worries with a normall bolt puller.
The Harmonic 'silent shaft sprokets' whats the best way to crack the nuts on them? With belt still fitted and rattle gun? Then they should just side off?
Any special tips/tools for getting the seals back on? Had to re do the cam's seal twice as the first time i fitted it the thing leaked worse than before i replaced it. Are the Blue seals that come with pump/belt kits known for being average fit or user error? Seemed a bit tight, and BNT one popped on with no worries.
Cheers Chris
Cheers Chris
