Needed ASAP D21 Brake Pad Shim/Christchurch!!!!!!
Posted: Tue Oct 30, 2012 4:58 pm
by BogBoy
As title
Needed a steel shim that sits between the front brake calliper hanger and the front brake pads. Left hand side lower?
Im in Christchurch
Num is 027 209 1025
Wouldn't put number up normally but desperate for one as need 4wd for course tomorrow!!!!!!
Re: Needed ASAP D21 Brake Pad Shim/Christchurch!!!!!!
Posted: Tue Oct 30, 2012 5:39 pm
by klompy
Just run without it,a lot of people just throw them away.
Posted: Tue Oct 30, 2012 6:57 pm
by BogBoy
klompy wrote:Just run without it,a lot of people just throw them away.
And it will be fine?
The pads are really loose with out them
Posted: Tue Oct 30, 2012 7:10 pm
by klompy
Yep use the brakes once and they will sit right.
Posted: Tue Oct 30, 2012 7:13 pm
by BogBoy
sweet. Will try it soon
Posted: Tue Oct 30, 2012 7:15 pm
by klompy
Pretty sure there only there to stop noise.
Posted: Thu Nov 01, 2012 9:51 pm
by BogBoy
Yea left the the left hand side ones out now they squeal and they are brand new pads/disk
Posted: Tue Nov 06, 2012 6:11 pm
by BogBoy
Still needing some please
Posted: Tue Nov 06, 2012 7:47 pm
by sibainmud
Are they single or double pot calipers? I might have some lying around but shipping will more than it may be worth. Have you tried around local to you?
Posted: Tue Nov 06, 2012 8:17 pm
by BogBoy
sibainmud wrote:Are they single or double pot calipers? I might have some lying around but shipping will more than it may be worth. Have you tried around local to you?
Twin pot, You mean try wreckers?
I thought I would try on here first but looking like a dead end
Posted: Sun Nov 11, 2012 6:12 pm
by BogBoy
Sorted!!
Thanks sibainmud!
Posted: Sun Nov 11, 2012 6:20 pm
by sibainmud
You're most welcome. Hope they work.
Posted: Mon Nov 12, 2012 6:08 pm
by u13turbo
Ussually vehicles are fine with out the shims, just chuck brake grease on the backing of the pad and it should be good as gold
Posted: Mon Nov 12, 2012 11:24 pm
by sibainmud
Read the post again.......the spring clips are what he was after not the backing shims. The clips that go at the top and bottom of the pad and cushion the up and down movement....at least that is what I sent him. Seams to be sorted now
Posted: Sat Nov 17, 2012 6:42 pm
by BogBoy
sibainmud wrote:Read the post again.......the spring clips are what he was after not the backing shims. The clips that go at the top and bottom of the pad and cushion the up and down movement....at least that is what I sent him. Seams to be sorted now
Yep what you sent was what I needed, The pads were really loose with out them and would squeal when putting my foot on the brake
Posted: Sun Nov 18, 2012 8:33 am
by klompy
Thats not how I read his first post
