Putting together new Toyota 2lt bottom end have a bare block, rods, crank and new pistons. Need everything else....On tight budget. Wellington area.
Also after Ln61 Interior parts, drivers kick panel, drivers armrest and plastics that cover rear canopy bolts.
Wanted, 2LT/2lte engine parts
Re: Wanted, 2LT/2lte engine parts
i might know of a 2lt turbo thats just been pulled out of a landcruiser, what sort of tight budget you mean?
Ive got an a/c pump, and an alternator.
027 MUD GEAR - (027 683 4327)
Check our facebook:
Could be keen on the a/c pump for air compressor conversion.
Tight budget means that i've got about $400 to put a motor together with at the moment!
Cheers.
Cheers.
- firestonecruiser
did u ask question on my trade me listing for 2lt manifolds. just an idea u may be able to use ore courier to get it to u. there cud be someone traveling that way.
cheers jono
cheers jono
Toyota_Surf
- Winch master
I got those rear plastic parts that cover the rear canopy bolts but i am in Auckland .U can have them for free. I'd send them to you but they are really brittle. PM when u r up in Auckland next time.
the 2lte i was talking about is for sale for $300, if your interested, was pulled out of truck because it was using oil, might be simple, may not, the guy with it pulled it out and put in a 3.0L
