Free 2.5" dump pipe for TD42, v band clamp, scarles turbo
motardbiker
Post by motardbiker »
Hey guys, made this pipe up to test run turbo setup, have cut off fitting for pyro but there is a hole to weld new fitting on, was on the back of a scarles turbo that was mated to sinco headers, dump pipe side of clamp is a 2.5" tri clover fitting which was slighly larger than the turbo clamp fitting but the v-band clamp took the slack up, had pretty good clearance, dont know if it will clear pto shaft but i'm going to take to scrappys soon so thought i'd see if anyone wanted it first, will just cost postage
http://i162.photobucket.com/albums/t264 ... 112601.jpg
http://i162.photobucket.com/albums/t264 ... 112536.jpg
motardbiker
Re: Free 2.5" dump pipe for TD42, v band clamp, scarles turb
dump pipe taken :D
