terrano oil light sender?
Posted: Wed Nov 07, 2012 5:46 pm
by grytvikken
Hi I have never had an oil warning light on my terrano 2.7td dash.... always going to fix it up but never did. I recently had to replace the dash and once again no oil light. Must be on the engine side of the wiring but where is the sender on the engine?
Any advice would be appreciated
Re: terrano oil light sender?
Posted: Wed Nov 07, 2012 6:42 pm
by sibainmud
Between starter motor and injection pump. Little bastard to get at :roll:
Posted: Wed Nov 07, 2012 7:06 pm
by grytvikken
thanks mate
Posted: Thu Dec 13, 2012 7:20 pm
by grytvikken
Any more info I cant bloody see it!!!!
Posted: Thu Dec 13, 2012 8:47 pm
by slide
Its just behind (further rearward) of the injector pump (drivers side of block).
If you can't see it, then either you're not looking hard enough, or someones removed it and bunged it up :?
Check Arvinslayers picture in this thread
http://www.offroadexpress.co.nz/Forums/ ... 4&start=15
You can see sender just above arrowhead pointing to fuel pipe. Next to dipstick tube in picture
Posted: Thu Dec 13, 2012 11:43 pm
by grytvikken
cheers slide
Posted: Fri Dec 14, 2012 8:40 pm
by Paulballz
its a single wire with black female spade like connector...shouldn't miss it, follow the main wire loom bundle going down from battery and it will come out roughly half way down, by memory green and yellow wire (don't quote)
Posted: Wed Dec 19, 2012 9:48 pm
by grytvikken
thanks mate
