wtd: 2lt Solenoid
Selling or wanted vehicles.
sldwys
wtd: 2lt Solenoid
Post by sldwys »
hey all, I need a few engine bay bits.
1.Rubber hose from Turbo inlet to Plastic Crossover pipe. (90 Degree bend )
2.Rubber/Plastic Hose from Other side of crossoverpipe to Airbox.
3.Boost Solenoid... I dont know how to explain this... but if your looking at your engine bay and you have solenoids on the right hand side by the firewall.. I need the one which is at the highest point.
in wellington! thanks!
imsohi
Re: wtd: 2lt/2lte engine parts
Post by imsohi »
hey in most cases the rubber pipes you are after are usually knackered i have always found toyota to do a good deal on these around $60 each. what vehicle is it out of ? if it is a ln130 surf i will prob have the solinoid let me know thanks
sldwys
Post by sldwys »
Hey mate, Yup it is out of an LN130 Surf, When I pick up the truck today from getting its WOF i will take a pic of the solenoid I am after. Thanks.
sldwys
Post by sldwys »
I have the hoses sorted, But I still need the little solenoid thing. Its the top solenoid on the right hand side above the fuel pump, Has a plug and I think 3x vacuum/pressure hoses coming off it. ( Im guessing this is what is causing my truck to not accelerate above 80km .... )
Picture is atatched. It is the Red/dull red Soldnoid on the top above the blue one.
