Fitting a 350 chev to your rangie.
Posted: Tue Jun 01, 2004 11:14 pm
by Athalus78
As the 5ltr died a while back and the repair quotes just keep getting bigger I was wondering what the hassles are with dropping a 350 chev in. IE, what gear box, manual or alternate auto? Engine mounts that kind of stuff.
Any info would be great thanks
Posted: Wed Jun 02, 2004 10:51 am
by Rangerat
Hi
Have a look at
http://www.rangerovers.net
There a bit about upgrading? your rangie to other engine makes, GM etc..
Rat
Posted: Wed Jun 02, 2004 1:37 pm
by Athalus78
cheers Rat I'll have a look
Posted: Wed Jun 08, 2005 12:09 am
by Athalus78
Well I ended up with a 302 windsor, stage three cam, high flow extractors, torqure manifold and some other bits.
It went well but you could feel the weight on the front axel and this ment that sand work was hard due to digging in. So the alloy 5 was dug out and the repairs started. Now the heads are as worked as they can be and a crane fire ball ingnition system is on board. As sone as the ute conversion is finished it should fly.
