Surf 2LT Boost light not working
Posted: Thu Nov 22, 2012 6:14 pm
by sg8380
Hey guys, when i turn the key to on the green boost light comes on but when i'm driving it doesn't seem to turn on when i can hear the turbo working, does any one know how to get it going?
also i noticed that the plug on the air intake pipe was unplugged so i plugged in in to see what happens but the car stalls as soon as it starts
Thanks
Sam
Re: Surf 2LT Boost light not working
Posted: Thu Nov 22, 2012 7:05 pm
by tweake
got a pic of the plug ?
and what model surf do you have ?
Posted: Thu Nov 22, 2012 7:07 pm
by Big
either unplugged, broken,no power or the air line to it has a hole, pulled off somewhere meaning there is no air to pressure the switch to tell it you are under boost.. check the lines and plug/ power to plug
Posted: Thu Nov 22, 2012 7:45 pm
by sg8380
hey its a 1989 ln130 heres a pic i found on the internet, i was to dark to take the photo, its the one at the bottom
Posted: Thu Nov 22, 2012 7:49 pm
by tweake
sounds like boost sensor wasn't plugged in due to it being faulty by the sounds of it.
it should be the D-turbo model ie not efi. the boost sensor runs the lights and egr setup.
i would leave the boost sensor unplugged and go fit a boost gauge.
Posted: Thu Nov 22, 2012 7:55 pm
by sg8380
will i still be getting maximum boost out of it with it unpluged?
Posted: Thu Nov 22, 2012 8:03 pm
by tweake
should be. fitting a boost gauge will tell you for sure.
i would also block off the egr and disable the egr butterfly.
Posted: Thu Nov 22, 2012 8:06 pm
by sg8380
what does blocking off the egr do?
