Nissan 4x4 diffs
Nissan 4x4 diffs
What model Nissan 4x4 has a rear axle that is fitted with disk brakes but is also fitted with a drum hand brake ie drum inside the disk.
- mud_slinger
- passengerpete
Re: Nissan 4x4 diffs
a wd21 terrano has one like that.
mud_slinger wrote:terrano?
Yup. H233B rear (same as front safari/patrol)
definitly the terrano, had so many problems trying to fix my hand brake.... gave up in the end lol
Dirtydog wrote:definitly the terrano, had so many problems trying to fix my hand brake.... gave up in the end lol
Yip, in the same boat
Feeking expensive little shoes too
Only adjust them up at wof time. After sticker put on window, relax the cable again so it can flex without pulling the cable on
Strong diff head and axles though.
Cheers guys, that helps a lot.
